Hi all!
Currently achieving the frame-off resto of my BJ42(1984 vintage) at the Toyota local shop.On the clock there are 200.000km or 120.000 miles registered.
By the first test drive the problem arised:the cylinder head is off!
We have decided to order a new cylinder head .
When the part arrived we noticed two things:first,it had a different number forged on it:58014 instead of 58010 on the original 3B.Second,the 4 combustion (or precombustion)chambers cannot be used in the new cylinder head because they are a little bit smaller! We understood that if we wanted to use this new part,we had to order its own combustion chambers as well.
No doubt the 2 cylinder heads are not identical,but the parts department told us that the older is not availale anymore,so the only way to go is the new part.
I knew that there are 2 generations of 3B engines:the first,1981-86 and the second,1986-1989.I knew also that the only difference between the two was in the fuel pump:in line injection pump in the first 3B generation and rotary injection pump in the second generation.The question is:is the cylinder head in the second generation different too??
If so could it be problematic to use these 2nd generation parts at the top of my 3B engine??
Thank you folks for your help!!
PS. SPECTER has two rebuild kits for the 3B as well
ne till 9/1984 and another one 9/1984-8/1988.
with you
