THe Offical call out # 82124 / 82114-90K08 / ENGINE WIRE No. 4 on a 1989 HJ61LG-MNXW w/ 12H-T OIL Pressure Sending Units SUB. Harness Thread (1 Viewer)
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
call out # 82124
82114-90K08
ENGINE WIRE No. 4
i have been asked to re-produce this mini OIL SENDER Sub. harness
it was just hanging there with NO home ?
that color code usually falls under the KEY ON Position ?
so anything can be at play here
My progress thus far leaving the black w/ yellow tracer long on the roll till the facts show them selves ?
Here is a 24V loom of a HJ60 ( 2H ) where the extra connector is used for the oil pressure switch to cut out the EDIC in case of low oil pressure.
And the answer is revealed! Nice job @sved.
Matt is building me that replacement harness for me as mine broke after 31 years.
So
first prototype I call a success that’s again and a huge shout out to @sved
you saved the day my friend and I mean that sincerity!
You will see a defent ball fearture on my soecial poitive grip OEM yazaki solid brass terminals I all used in all 3 locations
the button connector on the sender has a depression for this feature built in
Also : both the idiot light sender and the mechanical sender male tabs have a tiny hole the ball locks into
hence positive grip
Is a jis only feature
EXAMPLE of a OIL sender Button connector DETENT recess feature detail :
Again a BiG thanks to @sved :)
This is wjat to expect and nothing less then Toyota Genuine Yazaki JAPAN parts connectors housings and solid brass heavy duty spec. Terminals
I bump up wires guage to 16ga. From
Puny 20 toyota used or 22 even maybe it is
anyway too darn small for a long term service part needs
I over engineer and over build the TEcH , good fo me and good for Clients HJ and BJ and heck all FJ also
same skool if thought no matter the vintage toyota electrical application
ALL parts Chemical and UV rated Resistent ,
assembled the TOYOTA traditional way , by hand and with pride .. :)
Again, many thanks to @ToyotaMatt for bringing a lost part back to life. That’s his harness in my truck above, and it’s working great.
some more good solid tech on this topic coming up soon ........
meanwhile
engine wire #4
oil sender mechanical rubber boot
who and what DIESEL Engine Platforms use and or had one factory installed ?
