Hi everyone. So, I got this 1985 FJ60 that I bought from my neighbor. The car had been sitting for 10n years and was not running when I bought it. But after a lot of elbow grease, the car is finally running. Well, sort of. Here are the things I have done so far and the issues I've encountered:
Cleaned/repaired fuel tank (I'm putting a new one in)
New fuel filter and fresh high octane gas
Changed brake master cylinder
New battery
Replaced door window
Washed the upholstery(it was nasty but it actually came out very nice). I took out the carpet, disassembled the seats, washed it all and put it back together
Changed ignition coil and spark plugs (I'm waiting on new spark plug cables)
Checked compression. It ranges between 165, 155 and 150.
I've been looking at all the hoses going to the carburetor and they all seem to be there and connected
Oh yes. We gave it a good wash!!
Issues I'm having:
The car will not start without starting fluid. Once it starts, it stays running but it is a bit rough
The brakes still seem to have air in the lines even though I made sure all new brake fluid was coming out when I bled each wheel and no air bubbles. You have to pump them a couple of times for them to function well.
The power steering is not working. I added fluid and in the beginning, it worked fine but now it doesn't. I raised the car and turned 40 times back and forth thinking it had air.
There is an oil leak which I believe comes from the valve cover gasket as I see fresh oil in the very back on the cover and that is where the oil drips from.
Any thoughts on the starting issue (I believe it has to do with a dirty carburetor) and power steering?
New battery
Issues I'm having:
