I'm putting a 78 2F from a model 40 into a 85 model 60. I know the ps engine mount is correct and believe the ds engine mount is correct, loaner was a 83? model 60.
The 60 had no brackets on the frame so I had to replace them. I believe the ds frame bracket is mounted where it should be but...when I put the ps bracket onto the frame where I believe it should be the ds mount was about an inch from settling onto the pad. I know the motor sits in with about an 11% slant toward the passenger side. I know the ps bracket goes back, Its being held in place to show the orientation of the bracket to the frame. Why is it so low? wrong ds mount? when the bracket is even with the top of the frame it is to high..i'm stumped and can't move on till I get it figured out..
