I am currently experiencing another electrical gremlin. Yesterday I was leaving the hardware store and my FJ40 died as I was rolling down the road. It just cut out and powered down. I will be trying to track down the issue today. Wanted to hear what some of you might think it is. Hopefully it will give me a good starting point and things to try to eliminate along the way. Things I have tried so far and to note:
Vehicle-1972 FJ40 running a transplanted 77 2F
No modifications to electrical system-stock with no lights or accessories
Original wiring harness
Engine is getting fuel.
12 volt constance (cig lighter, hazard lights, dash light) all work
Headlights and all marker lights work
Battery is good and charged.
Previous electrical issues:
Bad starter has been replaced
Bad alternator has been replace
So when I turn the key I get nothing-no clicks. It appears as though no power is getting to anything when I turn the key. With the key on, the wipers, heater/blower do not work.
Things I have done so far:
Bypassed the coil and ignition system and was able to turn the motor over. She will crank strong but not fire
Checked all fuses-everything appears in order and I will be cleaning the contacts
Currently tracking down grounds-did this a few months ago so all should be clean and tight
Had the coil tested-it has resistance and the circuit appears to be good
Pulled spark plug and cranked motor-no spark/juice getting to plugs
So mudders is it possible that the ignition switch has gone out? Would that cause the engine to just shut down? Is there a way to test the ignition switch? One other thing to note, the vehicle has been sitting for about 3 months without running. Thanks in advance for your help
