- Thread starter
- #41
Called Napa...they will pick up/machine/drop off for $40. Lol
They actually charge 35 for flat and 40 for stepped...so, guessing they know. Any idea what actual specs are?Make sure they understand the stepped flywheel design (they should), heard on occasion where some won’t or can’t handle the step design.
Also, I doubt that rusty spare you have is bad, probably just surface rust that will clean right off. FWs are thick heavy metal, I just had the same rusty Toyota FW machined a couple weeks ago, looks brand new.
That other 10-20% would be ring gear chewed up, bad driving habits on an old engine, or bad luck?Yep, @MoaByte , that works fine 80-90% of the time.
exactly what I was wondering...I may need schooled on this, but if the FW appears in good shape, why not just scuff the surface with some emery cloth and call it good until the engine is rebuilt? This is a heavy FW on a low RPM motor. I'm asking to be set straight.
Usually poor driving which means lots of clutch slippage, leading to severely burned FW friction surface.That other 10-20% would be ring gear chewed up, bad driving habits on an old engine, or bad luck?
Thats what Im going to have done...ya!Did you do this?
seems the best way to go in your situation
