need new shackels (2 Viewers)
Alabama
Website
www.auburn.edu
so when I bought my 40 it had shackes that are way too long. so i am in search for CHEAP but worthy. i know those to words don,t go together, but I am searching. I want to be under 100 for all 4. I found these and wondering if any of yall are runing them?
http://cgi.ebay.com/ebaymotors/1-LI...ryZ33585QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
so when I bought my 40 it had shackes that are way too long. ... I found these and wondering if any of yall are runing them?
Whoa :eek: those are shorter than what you had before??
Those look scary long. Get some OME greaseable anti inversion shackles.
make some cheap.
get yourself some steel and a drill
Why don't you just make your own following Mark Whatleys article in the Trails. They are cheap and worthy.
X2. I made my own, and it was really pretty easy. 3/8" x 2" steel + 5/8" drill bit + 5/8" bolt and nut = cheap and STURDY shackles. It would have been much easier to use a drill press, but all I had was a hand drill. It took a little longer, but it was still really easy. Besides, if you make your own, you can make them exactly how long you want them. I went to the local steel place and had them cut 6" pieces of 3/8" X 2 ". All I had to do was drill the holes and buy the bolts.
Good luck! :cheers:
thanks for the help. the reason I was not makeing my own is that the steel shops around here are chargeing a ton for steel.
probably alot cheaper than buying premade ones?
go look in their scrap basket theyll have some cheap
