Need new radiator for 69 40?? (1 Viewer)
Santa Cruz Mountains,CA. TLCA#7702
Hi All,Time for a new radiator! Just wanted some thoughts or advice on where I should buy it from.Here is what I have so far:
Spector-4-core $330,club price$282
MAF-stock replacement $239
CCOT-4-row HD w/free cap and drain thing $257
All prices are plus shipping,oh yea its for my 69 40 with the 71 F engine.I will want to go to a 2F in the future,so this should be the same radiator?
Thanks,John
dgangle
total rice
Heart of Dixie
Radiators, automotive radiators, condenser, oem radiators, truck radiators
OPTION 1:
FJ4* SERIES ONLY - Manual or Automatic Transmission
Specifications
Core Size: 17-1/8 X 19-5/16 X 2-1/16
Inlet Header: 19-1/4 X 2-15/16
Outlet Header: 19-1/4 X 2-15/16
Inlet Connection: TOP 1-1/2 DRIVERS SIDE
Outlet Connection: BOTTOM 1-1/2 PASSENGERS SIDE
Transmission Oil Cooler: NONE
Engine Oil Cooler: NONE
Mounting:
Notes: 3 ROW ALL METAL
$188.64 1971 TOYOTA LANDCRUISER radiator
$0.00 FREE Shipping in the Continental United States
$0.00 FREE Lifetime Warranty
-$5.00 Online Discount
$183.64 IS YOUR FINAL COST
Please note that sales tax will be added if you live in FL, GA, SC, NC, AL, TX or NV.
CSF 180
OPTION 2:
FJ4* SERIES ONLY - Manual or Automatic Transmission - 4 ROW HEAVY DUTY MODEL
Specifications
Core Size: 17-1/8 X 19-1/4 X 2-9/16
Inlet Header: 19-1/2 X 3
Outlet Header: 19-1/2 X 3
Mounting: FRONT FLANGE
Notes: FOUR ROW, BRASS TANKS/COPPER CORE (ALL METAL)
$199.02 1971 TOYOTA LANDCRUISER radiator
$194.02 IS YOUR FINAL COST
CSF 2888
Kansastitty
That's the one I just bought. Seems heavy and quality. The only thing you might want to address is the drain cock. It is just a plastic plug and not very accessible when installed on a 40. No extension on it. I have not done the swap yet, so I don't know if the one off my current radiator will fit.
Ed
Charleston, SC
OPTION 1:
Specifications
Mounting:
CSF 180
OPTION 2:
Specifications
CSF 2888
X3. Nice quality. Shipping is fast. Seems to be holding up fine after a year.
dgangle
total rice
Heart of Dixie
...The only thing you might want to address is the drain cock. It is just a plastic plug and not very accessible when installed on a 40. No extension on it. I have not done the swap yet...
Yes, the drain doesn't have the extension tube on it like an OE rad and the plug is plastic but I found it to be easily accessable with pliers. Or just disconnect the bottom hose to drain. Non issue to me. The only issues I encountered were the side mounting flanges both came off soon after installing from s***ty soldering. No biggie, though. I resoldered myself and never became an issue again in several years' use. Also doesn't come with a cap as I recall but one can source that anywhere and are inexpensive.
I just replaced the radiator in my 1980.
I made a little tool to open the drain cock, by taking a piece of PVC sch 40 pipe about 4" - 6" inches long. In one end I cut a slit with the cutting wheel of my angle grinder (the slit is cut as if cutting the pipe length wise). In the other end I drilled a hole all the way through both sides, big enough to slide in a phillips screw driver.
I can push the pipe up through the skid plates & etc so thet the "wings" on the plastice plug fit into the slit. On the other end I slide a screw driver through and turn
Same can be done for brass plugs except use a grinding wheel to make the slit wider. It actually works better on the brass drain cocks because the PVC pipe captures the coolant better and neatly directs it into a bucket
The new radiator had the plastic drain cock.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
