Need New Fuel Tank
Discussion in '80-Series Tech' started by 80 Cruiser Rod, Nov 13, 2017 at 11:11 AM.
  1. GW Nugget
    GW Nugget I need to stop messing with it & just drive it!
    2,423
    Media:
    8
    Albums:
    2
    1,809
    Jul 25, 2014
    Coalinga, CA
    I'm in need of a tank, all I have found new or used is $600 & up.
    Were did you get your tank from? How much?
    Thank you for your time.
  2. megolfer
    megolfer
    2,051
    144
    Jan 29, 2003
    Gw nugget I have one out of a 92 i believe. Will it work
    GW Nugget likes this.
  3. Red Merle
    Red Merle
    1,146
    593
    Jul 7, 2016
    Twin Ports of Superior, WI and Duluth, MN
    Has anyone tried to bolster the area that commonly cracks on top of the tank by welding on a patch or something? I am going to be replacing my tank next spring, mostly due to rust present on the exterior, but I am worried that the new(used) tank might get the crack that we are seeing many of them get. If I could prevent that from happening, I would feel better about the situation.
  4. baldilocks
    baldilocks GOLD Star
    3,405
    2,926
    Jan 29, 2014
    Northern California
    Consider how many years went by before the few tanks that cracked did crack.
  5. Malleus
    Malleus
    1,218
    Media:
    13
    Albums:
    3
    595
    Jan 5, 2017
    Charlotte, North Carolina
    If you're worried about exterior corrosion, coat it in bedliner before you install it. I have three 80s with no damaged tanks, other than superficial surface rust. I cleaned one with 400 grit sandpaper after I took it out and resprayed it. Where is the crack you're referring to?
  6. inkpot
    inkpot SILVER Star
    11,821
    1,724
    Jan 30, 2003
    Chandler, Az.
    Might be pretty hard to duplicate the compound curves at the common failure point, but it would be an interesting test.
  7. BILT4ME
    BILT4ME
    3,879
    Media:
    3
    Albums:
    2
    3,246
    Nov 9, 2012
    Olathe, KS, USA
    @98 SNAKE EATER did his at one point here:
    Replacement gas tank......what are my options?
    There is another VERY large thread about the leaking tanks, but I could not find it in my brief search today.
  8. BILT4ME
    BILT4ME
    3,879
    Media:
    3
    Albums:
    2
    3,246
    Nov 9, 2012
    Olathe, KS, USA
    To the OP:
    Didn't you already buy one replacement tank for this? Did that one not work out? What happened with the tank and the rust? Let us know so we know what issues to watch for.
    I had a leaking tank a couple years ago and bought a used one from @slow95z in GA. He cleaned it all up for me, we discussed packaging and freight and shipped it out, along with some other parts.
    When I got it, it was nice and clean on the inside. I had asked him to clean it, rinse with alcohol and such so he could ship it with no fuel smell. Then he stretch wrapped the tank enough so it looked like a green cocoon. I was very happy with what I got. I installed it about 6 months later and it was still as clean as the day I received it.
    I also changed my charcoal canister about 2 weeks before I changed the tank (no point installing a replacement tank if you don't fix the real problem!)
    I've run it another 25K and no issues at all! I used my original fuel pump and sock (because it was still clean) and installed all with new gaskets. I coated the exterior of the tank with two coats of POR-15 to help offset any chance of future rust and I installed new rubber gasket strips where it touches the body.
    baldilocks and GW Nugget like this.
  9. GW Nugget
    2,423
    Media:
    8
    Albums:
    2
    1,809
    Jul 25, 2014
    Coalinga, CA
    Awesome, I PM'd you.
  10. Red Merle
    Red Merle
    1,146
    593
    Jul 7, 2016
    Thanks for the input. I am not sure exactly where the spot that people report the tank leaking, but I do remember seeing at least one pic somewhere on here that showed a crack on the top where the tank contours.
    I think I am just going to sand and POR15 mine and jam it in. I have a new charcoal canister and I switched to premium fuel after reading enough bad stuff about ethanol to convince me that it was worth the extra cash for the good gas. The truck does seem to run better on premium and I think the increase in MPG almost offsets the extra cost.
  11. inkpot
    inkpot SILVER Star
    11,821
    1,724
    Jan 30, 2003
    Chandler, Az.
    Here I. The Phoenix area regular and premium both have the same% of ethanol. Can't excape it.
    Red Merle and GW Nugget like this.
  12. Red Merle
    Red Merle
    1,146
    593
    Jul 7, 2016
    My Tacoma is from that area and it ran really rough when I bought it. After a tune up and several tanks of ethanol free gas, it now runs much, much better.
    Ethanol just seems dumb on a number of levels but the fact that it causes issues in older trucks is enough to make me adamantly opposed to it.
  13. PDoyle
    PDoyle
    2,085
    69
    Oct 5, 2003
    Saratoga Lake, NY
  14. Malleus
    Malleus
    1,218
    Media:
    13
    Albums:
    3
    595
    Jan 5, 2017
    Never heard of them until now. Looks good, but I've had lots of girlfriends who did too. Just sayin'...
    Have you used them?
  15. ppc
    ppc M Go Blue
    1,833
    433
    Aug 18, 2003
    Nashville, TN
    On their website it states "Holes in the Tank can be Repaired" which isn't very specific. I don't think that any type of coating will be adequate to repair the "cracked" LC tanks as it is more structural flaw than what a "hole" would be. Unfortunately they don't have any locations near me and I would want to see examples of the tanks they have repaired.
  16. BILT4ME
    BILT4ME
    3,879
    Media:
    3
    Albums:
    2
    3,246
    Nov 9, 2012
    Olathe, KS, USA
    I would never coat the interior of a gasoline tank on any of my cars, classic or otherwise.
    They state a non-transferrable limited lifetime warranty. If they really wanted to back it up, it would be transferrable.
    I have yet to hear of an interior coating that has worked for more than ten years.
  17. PDoyle
    PDoyle
    2,085
    69
    Oct 5, 2003
    Saratoga Lake, NY
    I had a Jeep CJ tank done many years ago. I remember it came out great. I saw the process and liked how the old tank was blasted, prepped and sealed.
    I haven't had the need to fix a gas tank again, knock on wood, but I wouldn't hesitate to do it again.
