Need help with transmission and transfer case options in an already 350 swapped fj40 with the original 3 speed. (1 Viewer)
Seoirse
Louisiana
Right now my 40 has a SBC and the original 3 speed and transfer case. I have been talking to some people in a local facebook group but I think I need some more opinions.
One guy said a fj60 4speed and split case will fit directly where my 3 speed goes no issue, and it is a superior transfer case.
Another person said the 3speed transfer case is both stronger and lower geared so it is better for off road anywas.
I already have my hands on a split case from a 60 series, so would that only bolt to a 60 series 4 speed? Would a 40 series 4speed work here as well? Is one better than the other? Are there any other transmission options I should be looking at that are easily swapped in place on the3 speed?
I am very knew to 40s overall so any help is appreciated. Thank you
reddingcruiser
Practicing for retirement
Supporting Vendor
Redding, California
The split case isn't going to bolt to your 3 speed and 4 speed trans isn't going to bolt to a GM bell housing with a 3 speed adapter. The FJ60 4 speed and split case is a good choice. At the end of the day all this will only get you 1:1 in high gear.
You need a 4 speed adapter bell housing along with the correct flywheel and clutch, and you can use the FJ60 transmission and split case.
KY
Easy is a relative term.
When I decided to replace the 3 speed in my FJ 40 that had been converted to a SBC years ago I went with the NV4500. It gave me overdrive that other conversions did do. The V8 was left where it was originally placed during the conversion following Downey instructions and parts. The NV4500 conversion via Advance Adapters put the shift lever back into the original 3 SPD location. I kept the 3 SPD one piece transfer case but added reinforcement pieces. The parking brake cleared the rear frame cross member, just barely.
You can go with which ever transmission you like, it just changes how much of your drive train is Chevrolet and how much is Toyota. Mine is all Chevy engine, bellhousing, clutch, transmission connected via AA to the Toyota transfer case and Toyota drive line.
The choice is yours.
Seoirse
Louisiana
Is there anything specifically great about the split case that would make it better than a 3 speed case? I pulled one from a junkyard but I’m not worried about not using it.
Are there any differences in the bolt patterns or gearing between an FJ40 and fj60 4spees?
Seoirse
Louisiana
This may be a stupid question but if I’m looking for an NV4500 should I limit it solely to Chevy transmissions? Dodges would widen that search.
Thanks for the help
reddingcruiser
Supporting Vendor
Redding, California
The one thing you can do with a split case that you can't do with the one piece case is upgrade the low range gear set to 4:1 gears.
Brea, Calif.
And then there is changing drive shaft lengths, and matching up drive shaft bolt patterns when switching from 3 speed to anything else.
Has anyone mentioned the hand brake will not be on US split cases. The split case also had lower gearing than the one piece that bolted to the four speed. There were slightly different gear ratios in different markets. No H41 offered here so ours was a little lower geared.
If you don't already have a a split case and not looking to spend a fortune on a new one can buy a used 10/82+ case from a BJ45/FJ45/HJ47 those will have the hand brake and are set up for the H55F five speed. These will have the 34 MM idler shaft not the later 38 MM shaft.
Seoirse
Louisiana
Damn a lot of good information here. I too am glad I didn't do anything else besides pull a split case before I came on here. I think I might try to wheel the 3 speed for a bit before I make any decisions. I am looking at swapping the 3 speed for a nv4500 mated to a fj60 split case. And since I will rebuild it while I bolt it on I might as well try and change some of the gears in it while I'm at it.
KY
Thanks for the help
Yes, it saves a lot of headaches. A lot of folks here prefer the Toyota external clutch slave because it is easier to change or work on in the field, I chose to go with the Chevy internal and simply upgraded the clutch master to a larger diameter for full travel.
Frazier Park Ca
When I was faced with the same situation I went with a Toyota 4 speed transmission and kept my 3 speed TC. It wasn’t too expensive and It’s been working for me for ten plus years plus I got to keep it mostly Toyota. You gotta love a V8 and a four speed!
Seoirse
Louisiana
pjohnson
Idaho
I have AA bellhousing (p/n 712532) I am planning to sell. No other parts, just bellhousing.
