Trying not to laugh too much. How long is this saga of inaction going to continue? But great pics. Hoping for some active investigation, to reveal at least one of the contributing suggestions. Cheers. 11B parts on offer in Australia.
No EDIC. Live by the sword - Die by the sword.Oil pump is driven by the crank. Situation would have to have been pretty bad for the oil pump to fail and the edic would have shut it down with low oil pressure unless bypassed.
Thank you, those are good points. The oil pickup seemed ok after a quick look. But I will check all oil passsages during rebuild. Going to shop for a crank tomorrow. A friend gave me the name of a machine shop that I will also call.Make sure supply oil passage are clear of any debris. I guess under size bearing Taiho are still available? Must be some good shop in your area which may even repair it to standard size?
oil pump drive spline get really worn sometime.
May have a look at the oil pump relief valve.
Sorry..
Thanks for update
That's crazy. Glad you could save the crank. I have the same fused brg material. But that brg is already at .050. So the crank was previously machined. Didn't know that when I bought the truck. Anyways, I brought the engine to the rebuilder yesterday and they'll check everything.I recently had main bearing seizure in my 3B. Snapped the bearing cap bolts and through the cap through the side of the block. The crank cleaned up fine with just a polishing, no grinding required. There a was a bunch of bearing material fused to the crank. I wouldn't be surprised if a shop can clean yours up with a polishing.
