Need Help with Parking Brake
Discussion in '60-Series Wagons' started by MJM, Aug 28, 2006.
  1. MJM
    MJM SILVER Star
    794
    36
    Feb 26, 2003
    Next to the Falls in OH
    I do not have the FSM for my 60 and have used my 40 manuals untill now. I am looking for a layout of the FJ60 Drivers side rear brake drum assemble. I have the drum off and need to find out why my parking brake is sticking on that side only. If you engadge it (pull the cable) it will stay that way untill you hit it on the bake side and force it bake. The pass. side is fine. Any tips or help would great. Is there any one part that fails or is it just a matter of lube.
    Thanks
    MJM
  2. Tinker
    Tinker
    2,865
    9
    Apr 15, 2004
    Larkspur, CO
    The bellcrank is usually the culprit. Pull the passenger drum off so you have a ready schematic & take the driver's side apart. You don't need the FSM if you've ever replaced brake shoes. The bellcrank looks like a fat "L" & pivots on a removable pin. I sanded my bellcranks down to remove the corrosion, filed out the slots they run in, & greased them with heavy synthetic. Now my rear brakes & my park brake work.
  3. seanzy1105
    seanzy1105
    175
    Media:
    14
    Albums:
    1
    Nov 19, 2006
    Minnesota
    the same f'in thing is wrong with mine, i put the transmission in reverse wen parking so it doesnt matter its just nice to have a parking break :confused:
  4. cruiser_guy
    cruiser_guy
    11,194
    26
    Jan 20, 2003
    Wherever the truck stops!!
    The older trucks have a stainless sleeve in the bellcrank pivot. Corrosion builds up on the pivot and it jams the bellcrank.
