Tank5
I need some help sorting out the wiring for an automatic shifter out of a 2003-2006 100 series, it would be used with the a750 transmission.
My shifter for reference:
I bought a second shifter to take apart to get a better look at the switches.
This is the plug everything goes through on the shifter. I don’t have a pigtail with the oem wiring to work from and I can’t find a reference in my wiring manuals that shows how the low gear switch should be wired or how the 4/3 gear switch should be wired. I was able to figure out the Shift Lock Switch wiring as the manual has a diagram for that.
I need help figuring out how the bottom two switches on the shifter are wired. A picture of the plug on the oem harness side that plugs into the shifter might help too.
