Need help with Alt. Belt removal
Knoxville
Trying to change out my altenator drive belts to OEM and am having a little trouble getting them off. Got the lock bolt, adjusting bolt and pivot bolt on the altenator loosened up, and assumed that the altenator would pivot about the top bolt, but it's not budging. Is the altenator supposed to rotate enough to be able to get them off? If so, any hints on getting this thing the bottom side of the alt. broke loose. Pretty tight space.
Thanks,
Rookie2
The alternator does pivot. Try loosening up the pivot bolt-mine was pretty tight. Then you have to loosen the adjuster all the way, which means even more than you think you need to. Even with everything loose, it's still a tight fit. I fit the belts over the alternator pully, then did the final install on the crank pully from below. The OEM drive belts are much quieter, but the Gates belts that i used the first time still looked new at 30k miles. Throw the old ones in with the tool kit to keep for spares.
Thanks for the response Andrew. I was able to get in there with a LFH and give the altenator several little taps on the bottom side to get it to pivot around. We're good to go.
:cheers:
Rookie2
