There is something wrong with the boost compensator. it should cause some change when applying 14psi to it. It should at least rev up when pressure is applied.
You can atempt to unstick it, Take it to a shop to have it done, Or just not use it and turn the pump setting up to compensate.
Tha latter should only be done with a pyrometer to guage the egt temps. Another by product is black smoke off idle acceleration or at least until the turbo builds boost.
The smoke won't hurt anything in the engine at low load, but the tree huggers might frown upon the extra pollution. Its Up to you.
Good Luck.
Good Luck.
