Brian/99uzj100
Hi S-Man, did you figure this out?
I have a Feb. '76 CA spec. FJ40.
The big tube on the drivers side of the carb goes to the EGR valve.
The solenoid on the front of the carb connects to a 4 wire connection on my rig, one goes to the front of the carb(prob. smog as already said), one goes to the EGR, and the other two go to the pressure sensors on my stock tandem master cylinder.
The capped tube marked #5 goes to my VSV (vacuum switching valve-smog)
The large capped tube on the front of the carb is the fuel return line.
You have 2 sensors on the head. The one by the carb is coolant temp. The one closer to the firewall that you have hooked up in the pic is a thermo switch for smog.
I think I skipped this thread initially because I saw WEBER in the title!
Good times!
Brian
Good times!
Brian
