Need help w/ 3FE Fuel injection harness
I'm in the process of rebirthing a 1991 landcruiser, however.... I wasn't the one that took it apart. So, I'm stuck and need some help. I took a picture and attached it to this post.
My question is : Where do these three things attach on the truck. I know one of them is a sensor (what sensor is it?), one is a ground and the other one looks like a dead connector on the fuel injection harness. All three are towards the back of the motor close to the firewall. Any help would be sincerely appreciated.
Sincerely,
Brandini :)
I believe, though I'm not certain, the small grey connector-looking thing doesn't actually go to anything. I know there are a few plugs like that in that general area on my engine, don't remember if that is one of them.
As for the other two... No idea.
Sincerely,
Brandini :)
The sensor on the bracket bolts to the lower intake manifold just in front of the rear 2 intake ports. It is the manifold temp sensor for the "carb" cooling fan. The grey connector is a jumper and connects to nothing. The ground bolts onto the upper intake plenum
Mine aren't quite as clean and pretty.
Thank you, thank you! :) You guys are a life saver. I LOVE MUD!
I hope to get this thing fired today... :) Installing the new injectors/harness, adjusting valves, New water pump, thermostat, new radiator and the upper intake. :)
YOU GUYS ROCK! Thank you :)
