It is with an incredibly heavy heart that I write this post. After dumping almost 30k into this cruiser, the engine seems to have completely seized/failed on the freeway the other day. I simply do not have any more funds to continue restoring this truck. I'm considering cutting my loses and I'm looking to the Mud community to help me understand what a reasonable price would be for this truck.
1985 FJ60 with 197,000 Original Miles, car has spent most of it's life in Southern California with a brief stint in Washington state. Minimal to zero rust.
Here are all the repairs and upgrades I have made in the last two years. Essentially until this engine seizure the car was some body work and new carpeting away from being a damn beautiful cruiser. Whoever has the cash to rebuild the engine is going to be walking into a lot of work already done for them. All repairs were overseen by Larry Bernstein of Dirty Parts in Culver City, CA.
So tell me guys, what would you list this for?
Radiator, Exhaust, Thermostat, Major Tune up, Leaks
Service Performed 10/13/2016
Radiator + Hoses
Thermostat + Gasket
Water Pump + Hoses
Fan Shroud
Distributor Caps/Rotos
Spark Plugs
Air Filter
Fuel Filter
Rebuilt Carbeurator
Catalytic Converter
Choke Cable Assembly
Oil Filter
Manifold Gasket Set
Head Pipe Gasket
EGR Pipe Gasket
Thermostat to Block Gasket
$5,348
Suspension
2/6/2017 Order Suspension Parts
All Old Man Emu
Leaf Springs
Nitrocharger Sport Shock
Suspension Bushings
U Bolts
Fitting Kits
Steering Dampeners
Shackles and Pins
2/21/17 Suspension Installation + Alignment
$3,131.70
New Fan Clutch
Service Performed 3/2/2017
Fan Clutch Assemby
R&R Fan Clutch
$455.72
Repair Starter Wire
12/31/17 - $85
All new brakes, power steering, steering knuckles, all leaks except rear main seal, A/C, Window Tint
Service Performed 11/14/2017
Disc Brakes + Drums (front and rear)
Disc Brake Pads
Drum Brake Shoe
Wheet & Master Cylinder
All new brakes hardware + hoses
Steering Knuckle Service
New steering knuckle bearings, seals
Power Steering Pump
Power Steering Hoses
Oil Pan Gasket
Push Rod Cover Gasket
Valve Cover Gasket
Crankshaft Seal
Timing Cover Gasket
AC Compressor
AC Recevier/Dryer
AC Fittings (high and low pressure)
A/D Drive Belt
New FREON
Window Tint
Radiator Cap
Timing Cam Sprocket
$7,317.18
New Transmission + Clutch, Exhaust Manifold Machining
Service Performed 5/18/18
Clutch Kit
Crankshaft Seal Rear
All new internal transmission parts
R&R Transmission/Clutch
Gasket Set for Exhaust Manifold
Resurface Flywheel
Resurface Manifolds
$4,611.81
Window Regulator (Driver Side)
7/11/2018
$342.95
Clean Idle up Valve
8/9/2018
$175.95
Extras:
JVC Head Unit + Installation: $209
Bosch Battery (3/16/2017) $137
Wiper Blades - $25
New Speakers - $300
Total repairs: $21,466.41
Radiator + Hoses
Thermostat + Gasket
Water Pump + Hoses
Fan Shroud
Spark Plugs
Air Filter
Fuel Filter
Rebuilt Carbeurator
Catalytic Converter
Oil Filter
Manifold Gasket Set
Head Pipe Gasket
EGR Pipe Gasket
$5,348
Suspension
All Old Man Emu
Leaf Springs
Suspension Bushings
U Bolts
Fitting Kits
Steering Dampeners
Shackles and Pins
$3,131.70
New Fan Clutch
Fan Clutch Assemby
R&R Fan Clutch
$455.72
Repair Starter Wire
12/31/17 - $85
Disc Brake Pads
Drum Brake Shoe
Power Steering Pump
Oil Pan Gasket
Valve Cover Gasket
Crankshaft Seal
Timing Cover Gasket
AC Compressor
AC Recevier/Dryer
A/D Drive Belt
New FREON
Window Tint
Radiator Cap
Timing Cam Sprocket
$7,317.18
Clutch Kit
Resurface Flywheel
Resurface Manifolds
$4,611.81
7/11/2018
$342.95
Clean Idle up Valve
8/9/2018
$175.95
Extras:
Wiper Blades - $25
New Speakers - $300
