I am going to be flat towing my new lx470 behind my motorhome. the procedure is to insert the key into the ignition without turning it to unlock the steering wheel, trans in park, and T-case in N. With the key in the ignition, there will be a slight battery drain. I have a 12v charging line coming from my motorhome, but I want to disconnect the power to the ignition switch without disconnecting the entire battery.
Can anyone help me out and figure out which fuse I need to pull/install a fuse switch???
