in the middle of changing out clutch, rear main etc.. The freakin rear main is PITA
I've gone through two already. From the pic below on the lower right hand side the outside layer of rubber was torn off as I was putting it in. Is this gone to cause the seal the leak or will this work. This is the last seal I have so the cruiser will sitting untill I can order more.
Opinions Please
TIA-
Opinions Please
TIA-
props to you. After no-joy with that method I ended up cutting a piece of plexi-glass and drilling holes in it to match the flywheel bolt pattern. Then little at a time turn the bolts untill the seal was seated. This worked awesome, the plex-glass was nice because you could see what the seal was doing. I wish I would have of thought of this earlier. Besides the rear main and getting the tranny back in. This project went smooth and I'm pretty F'in proud of myself for accomplishing this feat. Now my cruiser is leak free and has a nice new clutch. Thanks to Tim and Sean for all the help, I owe you
