I have some rust along seams in the front floor pan. The pictures attached are looking up from underneath the truck on both sides. This section of floor angles up towards the firewall (where feet would hit inside if you extended them forward). Not a normal place where I would expect to see rust since it isn't a flat surface where water could stand. There is no rust on the floor pan inside under the carpet other than where it has rusted through from underneath at the seams.
It appears there is a housing attached to the floor on both sides where water/dirt may be getting in. The housing is at the very top in the last picture with the rust hole. There is a small rubber plug at the bottom of both housings. When I removed the plug on one side a lot of dirt came out. How is water/debri getting in there?
