need flex help
just got back from wheelin and I need more flex or something I have a 5" pinnical lift any one have some ideas for some flex? I still like to drive on the road but I need to do something I was thinking sr and revolver shackles for droop what do you guys think? :-\
Frankfort Ky
Website
www.threeelementsdesigns.com
Well, for starters, any 5 inch lift springs are going to ride roughly. I use 2.5 in springs and 1.5 lift shackles to get 4 inches, just right for a little trimming and 35s. I had to soften mine up aswell. Make sure the springs aren't rusted together, and that there are some liners to reduce friction. I like teflon myself. Next check that none of your spring eye bolts are overly tightened. While your at it, grease the bushings with some high quality synthetic grease. Make sure your shocks are in good shape. Try removing them and seeing if that helps, but don't drive that way for long. I would suggest removing one or two springs, depending on how much lift you can sacrifice. If this doesn't help, get new springs!
my lift is only about a year old so there isn't any rust and it has pads between the springs I pulled out the spring clamp bolts but maybe Ill try taking some leaves out any other suggestions?
Boise ID
I would start by opening up the little cage that wraps around the sping. When I did this to mine they flexed a ton more.
mine doesn't wrap around it had bolts threw
Make sure your shocks aren't bottoming out.
