Wanted Need Early 1960s OEM Flasher/Bracket, Fuse Block, Generator, Fuel Pump (1 Viewer)
OEM items needed for a 1961 FJ40.
1. Turn signal flasher and bracket.
2. (5) Five-fuse, fuse block. FOUND.
3. Generator.
4. Hand-prime fuel pump. FOUND.
Need shipped to 28435.
Thanks!
Do you have any pics of the fuse block and generator you are looking for?
Thank you for asking. Here are some photos I found on Mud (not mine).
First is the correct generator for a 1961 FJ40---oval Denso tag with part # FJ40-27000
Second is a generator said to have come from a 1963 FJ40---rectangular Denso tag, not sure the part #.
Third and fourth pics are front and back of the fuse block I need.
I don't have the generator, but do have a fuse block and cover from a 69'. Would that work for you?
I am not sure which year the fuse blocks changed from five fuses to six fuses. But I do know that a '61 had the five-fuse block. Which one is yours---five or six?
If yours is a five then we might be in business. Got a pic?
Found a couple items. Edited original post.
Still hunting the generator and a turn flasher & bracket, though.
Thanks.
