Hello Everyone, need a bit of diagnostics help here.
1981 FJ40, all stock except it is lacking the dual diaphragm vacuum advance but I'm not at altitude. Been doing a ton of work on it but not much under the hood. Things that have changed under the hood since I acquired it in late 2019: valve adjustment, air filter, belts, and timing gear cover. The vehicle has always suffered from difficult cold starts. Full choke, turns over a couple of times, catches and runs for a second then quickly dies, do it again and it will run. This has progressively gotten worse and on cold mornings it may take 3 or 4 repeats of this before it runs. It also needs to idle for a long time before you can start letting in the choke. Before the belts and timing gear cover, the high pitched squeal started so those changes shouldn't be a part of the problem.
Squeal happens intermittently during idle and while driving. Does not seem to have any relation to braking, clutch, throttle. It just comes and goes. This morning the stalling at idle happened while coming to stop signs was a major issue. It did this at every stop sign on the way to work but then after sitting for about 9-10 hours at work, it started great and drove great on the way home. The squeal seems to go away as the entire engine compartment warms. I posted a video of it idling and revving here:
This was from today after I got home from work.
This video:
Shows the difficulty of the hard starts, the overall engine noise and you can hear the squeal begin at about 1:06, this was from this morning.
Sincerely appreciate any input on helping chase this issue down.
This video:
