I just finished the rebuild of my front end on my 95 fzj80. I replaced all the bearings/races, seals, rotors and also the brass spindle bushings. I did not replace the brake pads because they were replaced about 3 weeks ago with 100 series pads and have plenty of meat on them. One of the caliper mounting bolts was missing its washer. I re-installed that bolt on the top of the caliper just in case it backed out the caliper would have less a chance to bind up with the wheel and lock it up. Going to replace the bolt/washer asap.
I just took the cruiser on a quick 8 mile test drive around the block and then onto the freeway. On the freeway, while coming back, I was going about 65mph. All of a sudden the truck started making a horrible, extremely loud whirring/squealing noise. I pulled onto the shoulder and parked. Got out to check for any signs of the noise and saw nothing out of the ordinary. Started her back up and got moving again, the noise didn't continue. I got off the freeway and decided to get fuel. As I was driving down the road towards the gas station the noise came back. I was traveling about 35mph this time. I slammed on the brakes until the noise stopped, at around 5-10mph and then accelerated, the noise stopped. I've checked the brake dust shields for contact on the rotor and they arent touching, I've also jacked the front end back up and checked for loose wheel bearings and there is no wheel movement.
This is my only mode of transportation and I need to get to work in the morning. I need to get this resolved as soon as possible so that no major damage to the axle is done.
Thanks for any assistance you can give me.
