Need Advise on who should do the work ?
ATL, GA
Website
www.mybj40.blogspot.com
Here's the quick story: I took my truck to the toyota dealer (like a :censor: ) and had themdo a front axle service because the truck was wobbling down the road pretty bad. Now the problem is back after only three months / 6,000 miles, and the truck wanders like a three legged horse. They said they replaced everything from brakes to bearings / repack.
So I have called the dealer and told them I thought they should reservice the truck for free and they just want me to bring it in and they will look at it. Should I believe them or cut bait and take it to the local specialty shop here, which is where I should of taken it to begin with !
Any advise would be great. thanks.:confused:
Toyota warrants customer pay repairs for one year from the date of service. If something they worked on has relapsed Toyota will cover the repair. The dealer is not in a position to commit on what they will do until they see the vehicle.
D-
You've already paid them so you need to go back and let them take a look. My advice is talk with them and get involved in the process back in the shop. Your tires could be underpressured, you could have a bad tie rod end or your steering gear could be worn. If your shocks and steering stabilizer are shot, that could affect steering and tracking. With it up on the rack you can grab each front wheel and get a lot of answers pretty quick. You can feel if the hubs/bearings are loose, and with someone on both wheels, you can see if the tie rods are worn. Just talk to them and work through it. And be nice. :) :) :)
I agree-be nice but factual and honest. Let them know what you expect without making "demands". Generally, they will want to help you. If they clearly messed up and won't stand behind it, then get more forceful. I hope it's just a loose wheelbearing. Good luck.
I must agree with CruiserDrew-if you are having the problem again, go in with the attitude you want the problem fixed reguardless of fault. Talk to the service mgr. & writer at the same time.
I wrote service for 4 years...taught me alot about people skills.
Come in & show both mgr./tech/service writer your concerns. Possibly a drive with all parties invloved so the specific issue can be documented.
Explain to them you want to participate in the investigation....
(remember your in the techs hands so try & make friends with him while there)
OH yea....bring donuts & juice to the techs the day you bring it in....a kind jesture can go along ways.
I would agree that since they already got your money the first time and this time should be free of charge you should give them a shot. That way if the problem persists take it to a reputable shop that is capable of diagnosing the problem and have them foot the bill for that as well. Seems only fair to me.
Although I'm not going to dispute that the above statement is probably true I think it kinda sucks that one should feel it necessary to bring in snacks for people in the service industry to encourage them to do there job correctly. They are in the business of supplying service correctly for monetary incentive not food. If I ever felt that way about any shop doing work for me ........................... well lets just say they wouldn't be doing work for me.
It's only free if the problem is related to the original repair. If it is something new it will not be covered. Toyota pays the dealer to perform a warranty repair so it is not likely that the dealer would "invent" another problem in order to get paid. That does not mean that it could not happen but it is not likely. A "normal" dealer will be wanting to be sure it is resolved in a timely manner with a minimun of inconvienence to the owner.
It is critical that you not start out with a chip on your shoulder. When reasonable people meet to resolve something it goes much better. If, and only if, that fails should you become "difficult".....;)
D-
Thanks - I am going to take it over there this weekend and start out nice - but forward in that I want it resolved. I needed some wisdom and got it from some cruiser heads. I am looking forward to working on my truck one day and with a support network like this I cant go wrong. and if I do someone will let me know.
thanks again.
OK , so I have taken the truck over to the dealer and they are saying that it is not the work they have done but the added lift that is creating the problem. I have the OME regular ride height on the truck. They did the work this summer on the axle with the lift on it. What are they talking about.
fuel- did you install a caster correction kit with the lift? If not, this could cause your wandering problem.
Even if I went with the OME lift hight ? I thought that the correction kit was not needed unless you went higher. (slee site). I know I did get about 1/2 inch of lift. I also can hear a wierd sound coming from one of the wheels in the front.
Geddes,
You have to get control of this. You're losing it and here's how/why. You took it there and were told "it's the lift's fault" which you dutifully reported here. That's it? That's the sum total of explanation you accepted from them?!!
I'm sorry if this comes off rude or similar, but here's how it would have gone if it were me:
Service writer: It's the fault of the lift
Me: What to you mean?
writer: The suspension geometry is off because of the lift
Me: What is the caster/toe in, and camber that you found?
writer: Um, well we didn't actually put it on the alignment machine
Me: So, you're making a few reasonable assumptions here which I understand, but the truck was worked on by you WITH the lift on it and it ran fine for a few months. Now, it feels like something is loosening and I can hear a humming or vibration from one of the wheels starting to get worse. So I understand what you're saying but I don't think the lift is at fault - there's something loosening at the wheel. Could we put it on the lift so that you and I can pull and yank on a couple things?
writer (now gently cornered that he really has no data to blame it on the lift): Um, let's talk to the tech and see what was done.....
From here, you can gently persuade them to consider that there is a wheel bearing issue developing that is likely their fault.
Don't ever walk away with such a 'topline' explanation that is not backed up with an actual technical reason why such and such is true. Once you leave, you end up in the uncomfortable position of being back and questioning their judgement call after it was already established by you leaving. It's much better to question it WHILE they're trying to hand you an explanation that doesn't wash in your opinion.
At this point, I'd call and personally speak with your service writer and explain that you feel uncomfortable with it based on some technical folks in "My Landcruiser Club" and would like to bring it in for another look.
DougM
thanks, They still have the truck and I am grateful for your post. I will call and try a more refined approach asking for numbers. I did get the feeling that they did not have anything to back up the claim. I will try again and see what I get.
thanks again. ..
thanks again. ..
Sorry, I didn't catch the "regular ride height" part on the OME. Please disregard my comments, you shouldn't need caster correction. Idahodoug presents excellent advice, as usual.
Went up the food chain a little and they cant give me numbers on the alignment machine. so they are going to put it on and call me. They also said it looked like my tires where over sized and wearing a little funny on the inner edges and that could be causeing my problem. I am getting the feeling they dont see many modified trucks ever.
Hmmm, probably several of us with regular height OME and slightly larger tires (285's here) w/o any problems at all. My totally unqualified, nonmechanical opinion is that something smells on their end. I've not had any work on the front end necessary since dealer under warranty redid the PS knuckle right at 60K because it was leaking.
All right for anyone whos following, they have re-checked and they still say no problem with the wheel bearings or axle and they say they put it up on the alignment machine (but could give no numbers) said they adjusted the toe and rotated the tires but no change. They still feel that it is my upgraded OME regular ride height . They recommed OME or cater correction. (d-uh)
I am picking it up tomorrow , I think I should of brought in donuts for the service tech. I will be taking it to my local land cruiser shop for service.
You wont believe it. So I pick up the car today from the shop to take it some where else and as I am driving down the road. I noticed the oil pressure gauge not reading anything and at about that moment the truck dies on the interstate. I jumped out and checked under the hood and all seemed fine. I then let it sit for a minute and started it back up. Now there is a Knock in the engine.... Maybe a high end knock and oil pressure seems to be reading but falling after a while. I limped it over the the local land crusier shop and they are looking at it right now. So is this just bad luck or what ?????
dam...
Possible loose crank pulley allowing the oil pump drive gear to "spin" on the crank. Did you lose power steering assist too?
