Have a 98 LC that we purchased 6 months ago for a great deal. I've learned why somethings are a great deal but also understand that once fixed, my LC will be all I want it to be.
My dillema:
Got a call here is what they found:
(2) seals 27761 (CR Seal) @ 22.41 ea
Pack wheel bearings - $111
(2) Differential mounts - $155.07 ea
(1) upper diff stopper - $40.83 ea
(1) lower diff stopper - $14.75 ea
(4) hours labor @ $90ea
Thrust Angle Alignment - $56.25
(2) CV Axles (12mo-12k warranty) - $161.41 ea
Total with sales tax: $1525.79
So.. my question is this - does the above sound possible? Do I need both CVs? I didn't notice grease on the other side but I didn't LOOK either.
I was talking with my co-worker / partner and he said we could do this ourselves and save $500 in labor. Hes never done cvs though.. are these difficult? Are they held in with snap rings?
Also, Schwab is charging $111 to pack wheel bearings, my friend said its simple...and doesn't take very long. Is it?
I've done CVs on small import cars and my Yamaha rhino in the past - just pulled it out and put the new one in.. pretty simple..
How much harder will this project be on my 98 Landcruiser?
Any special tools or things to watch for? Preferred parts to buy / not buy?
ANY AND ALL help / advice is greatly appreciated! Looking to move forward ASAP!
Im located in Kent, Wa - anyone around interested in helping some noobs or have suggestions on where to get parts, etc?
Thanks for your help in advance!
Jarrod Foster
Jarrod @ OlyFinancial.com
253-479-1334 or 253 670 1684 (cell)
My dillema:
a few months back, I had a clunk when starting and stopping; thought it was the drive shaft issue and I ignored it. Started seeing a leaking oil.. had it towed to my mechanic; found the rack and pinion was bad. Had it replaced, steering was great.
Little clunk was still there; told my wife - ignore it its the driveshaft that evryone talks about on here.
I then removed my side steps and cranked my torsions a bit to level it out.
Yesterday (2 mo after cranking torsions), we had some 285/75/16 BFG ATs put on. While it was up in the air, I noticed grease from the drivers side CV..Ugg. Dropped it off this am at local Les Schwab to replace it (thought quick, cheap and easy)..
1. My front diff mount is toast and my diff has been shifting around. Need new diff mount and upper and lower stoppers?
2. Because my diff has been moving, I need BOTH front CV Axles
3. Also, both sets (4) wheel bearings are bad too.
(4) bearings @33.20 ea2. Because my diff has been moving, I need BOTH front CV Axles
Jarrod Foster
