Need advice. Cowl to apron gap. (1 Viewer)
Oregon
There's about an 1/8" difference in gap between cowl to apron in comparing either side. Closing the hood makes it even more apparent.
Which gap is correct? I can adjust accordingly.
Driver's side looks good.
Ignore it
Many seem to have one bigger than the other. If everything else lines up (i.e. you don't have overbite or underbite at the front of the hood), then don't worry about it.
Ok thanks. I am about the start the hood/fender alignment process. There is likely enough adjustment available to make either gap work.
Plan is to square up hood first, then adjust fenders to hood.
I just did this a couple months ago. Mine is very similar to yours. Bigger gap on the passenger side. I left as is and everything lined pretty good.
