FJben, is that just bending down the steel lines then?
CodyRx7 said:Thanks for the headsup.
For the front bumpstops...is there a bolt deep inside the center of that "cone"?
CodyRx7 said:Nope, and nope.
I wanted to get the lift installed since I already had the 35"s put on. I kept reading that you'd only get a tiny bit of rubbing on the innermost part of the fender at full tuck if you had 35"s on a stock suspension truck.
Well the black line around the bottom of the sheet metal from just SLIGHT travel said differently.
I even broke one of the mounts for the passenger rear flares, which is why it sticks out a bit.
I didn't want anymore of that body damage, so the lift needed to go on.
I won't be hitting anything but pavement until I get the bumpstop, swaybar, and brakeline extensions tho. Are the extended brakelines just the single hose to each axle?
CodyRx7 said:FJben, is that just bending down the steel lines then?
CodyRx7 said:I double checked, they're 75s not 70s. The Nitto website shows 34.49" inflated diameter.
rtiqulatendisco said:I have 0 vibrations with the j springs. Only extra weight is the ARB bar. I'm going to put a .5-1 inch spacer in the front, add a warn winch, regear to 4:88, and put on 315/75 BFG MTs. Want to go with the slee rear bumper since i live so close to his shop but ironpigoffroad has one for $500 less
Also, I already have the castor plates from slee.
rtiqulatendisco said:Want to go with the slee rear bumper since i live so close to his shop but ironpigoffroad has one for $500 less.
rtiqulatendisco said:Lance said he would have them in a couple of months back in March!!!
Here is a pic of the truck with 33's and j-springs...no vibes.
rtiqulatendisco said:No, trxus MT's. Go with BFG, the TRXUS don't last too long with the weight of these trucks.
(pre-swampers, but still 315 Discoverer S/Ts).
notyourmom are those 35x10.5?
