Got a nasty crack in mine. Time for a new one. Any recommendations in the Phoenix area for a new one installed the proper way? Thanks in advance.
I just had some chips repaired yesterday by them and they said if I do end up needing a new one that they would let me bring the glass in if I wanted to use a Toyota part. They also said they would look at the FSM instructions if I brought those too, since it's apparently kinda tricky to get the 80 glass to seal properly. That is the route I would probably go if need be.Safelite uses Chinese made glass. Just FYI
Is there such a thing as actual Made in USA glass?Safelite uses Chinese made glass. Just FYI
A P Tech glass from Safelite with a DOT code 1005 on it is made in Enfield, NC. According to the research I have done. Some other A P Tech glass with other codes appears to be made in China.
Yes, I used to haul it on a double drop, used for anything from automotive to architectural. Plants all across the US. They may not make the glass for our application, but US glass does exist.Is there such a thing as actual Made in USA glass?
Cardinal glass out of Madison, WI has one of the few glass factories still going big. They don't do as much as they used to in Madison anymore, but they are in the top three for glass in buildings, at least they were.Yes, I used to haul it on a double drop, used for anything from automotive to architectural. Plants all across the US. They may not make the glass for our application, but US glass does exist.
