G day l have a problem I think it is the glow plug relay just need someone to check if there is power on the yellow and black wire when you turn the the key to glow . because mine does not have power I also found on the starter relay one of the connection was burnt any reason why any help would be appreciated
I assisted with a re-wire on a 1984 HJ47 recently. I am recalling the yellow with black stripe and the black wire run from the glow plug relay you have pictured across the dash to the glow plug heating element which is the screen below the head light switch on the left of the dash. Bit of an odd design but inside the screen on the left of the dash is a heating coil that glows red when the key is held in the glow position. It was burned up on the 47 we just re-wired so we bypassed it. I could be wrong on the colors as I am pulling this from memory, check the wiring diagram to verify.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
