Alright so it's really obvious after doing a search that this topic has been posted many times before. It seems however that a lot of the threads are problem specific and don't cover the whole picture. I have a FSM for the 2F that talks about WHERE the carb should be set for maximum performance. The FSM also covers the lean drop idle and all of this. Maybe I'm tired of smelling like gas (I have an open header) or maybe I'm just not going about this the proper way.
My carb has 4 screws...Idle mixture, Fast idle speed, idle speed and the AC idle up which I'm not playing with until I get all of this sorted out.
The carb is rebuilt and if I use the choke it will idle just fine around 1200 to 1300 rpm (which is where it should be right?). The FSM wants me to set the fast idle to 1800 rpm, I'm thinking that excessive. My problem is when I push the choke back in the truck will not idle. I've messed with the screw for it and I'm not really sure what I should do...screw it in more or back it out more??? This is where my dilemma lies.
I don't really want to tune this thing with an open header, but I can't get the rig to the exhaust shop a couple blocks down the road unless I can get it to run. With the choke pulled out a hair I could probably get this to the exhaust place, but I'm ready to cruise guys I've been without my rig for a couple months while I had the carb rebuilt and I installed the header and desmogged the rig.
So far this is what I know about tuning the carb;
With the choke pulled out completely adjust the Idle mixture until I get the maximum rpm using the Idle mixture screw. Adjust the Fast Idle screw with the choke pulled to about 1200 rpm. Then adjust the Idle screw with the choke pushed in to around 690 rpm.
Does that sound about right? I just can't seem to get the last step of this down correctly. Can I turn it completely CW or CCW to get the rpms way up there and step it down from there? Which way to turn the screw? There are my problems; I'd like to get this turned (somewhat) tomorrow and in the hands of the exhaust gurus down the road.
Thanks!
Thanks!
