I'm going to address this, either in the morning or on my days off. It now turns out that I should have Saturdays and Sundays off, so with a little direction should have ample time to address issues.Did you clean up the bolts and washers and mating surfaces of your new starter ground wire? Not the root of your problem but won’t hurt either.
This thread is awesome! It looks like @hodag and @zcruiser really saved a lot of time, money and potential frustration by going down this route. The next time it doesn't start and I give the starter a thwack like @Seth S suggested, this might be the route to take...as well as maybe the relay as well. Y'all are truly awesome!!I have searched for you and found a starter rebuild thread here:
Here are the Toyota part #s for a starter rebuild.
I just got done rebuilding the starter on my '87 and I thought I would share the part numbers for the contacts and the plunger. I got the parts from Cdan, and he had to cross reference the numbers for a 3FE starter in an early 80 series. The Toyota computer does not show the individual parts...forum.ih8mud.com
You can bypass the trucks starter trigger wiring by getting a remote starter switch.
Many folks will disagree with me here but if it turns out to be the starter, I would just get a denso reman'ed through Toyota. I have tried aftermarket stuff and its just garbage. The denso starters are a bit expensive but you most likely won't be replacing it anytime soon. I personally have been burned too many times to play that aftermarket game any more.
I must say I've been a little stubborn so far...it's like I ask for help but don't take it when it's offered. I think being ignorant to a lot of this stuff feeds me uneducated fear that one or two of these things, like the remote start, would actually work but would bypass the issue at hand. After you explained it the way you did here, I feel a lot better about trying that first. Also, with replacing the full starter instead of just doing that rebuild as suggested on that other thread, my dad told me to do that as well. He basically said the same thing...and if I did that, I'd be starting off with good parts that could potentially last a very long time. I don't want a crap unit that I'll have to rebuild several times over the next 10-15 years, but I also don't want to go to Toyota and give them an arm and a leg. I'll clean up the connections to all of the cables this weekend and I'll check to see what, if anything, is going on with the fusible links.I have seen where this is a common route to take. So much so that many folks claim to just do this as one of the first mods they do on these trucks.
Before you go down the road of adding a relay let me offer this up. I mentioned this way back on page 6 but will do so again here. Try using a remote starter to bypass your trigger wiring. This is roughly the same as doing what @Seth S's video shows. If it cranks with the remote switch and not with the key, then you know the battery, cables, solenoid, and starter are good. You can then assume its the voltage through the trigger wire and can then either seek out the issue using a multi-meter or wire up the relay mod. If it doesn't crank then your trigger wire is OK and issue could be sticky solenoid/starter, connections, etc. However as others have said, if banging on the solenoid makes it work after turning the key doesn't, then you can focus on that being the issue. The remote starter idea is literally 2 minutes to try. I got one at Autozone for like $16. I only mention this because I went down the same exact road as you. I was able to rule out my trigger wiring as the issue using the remote switch idea, purchased a new Toyota/Denso re-man'd unit and have never looked back. Problem solved.
While fixing the solenoid is possible, I would just replace the starter if it seems suspect. If the solenoid is going bad who knows how long you have with the starter itself. Everything on your truck is ripe for replacing if it has not been done. There are certainly worse issues in this life than buying an unneeded starter for your 30 year old vehicle. Even if it does not fix your issue, you know its been done. I realize this is throwing parts at a problem a bit, but your issue can be only a handful of things at this point. Ruling one out wouldn't be the worse thing in the world.
The fact that jumps get you going still seem to me to be something with the power delivered. I have seen plenty of batteries that test 'good' and yet can't crank a car over. Maybe have the battery tested by someone who is not on the hook for giving you a new one if the test fails. I would also clean up the contacts on the starter. Looks pretty messy in your photos. And again, check the fusible links. GL. HTH.
It’s most likely a sticking problem in the starter solenoid. I have ordered the parts. Cruiser Dan (cDan) is no longer at American Toyota in Albuquerque so I used the part numbers from that other thread to locate the parts on ToyotaPartsDeal.com. Less than $70 with shipping. Just waiting for them to get here. I also checked the oil pressure sender. It seems to be aftermarket...I’m having trouble getting the wire out of it so that I can test it to see if the unit itself needs replacing, the wiring is bad or the gauge is bad. I can get the parts from the website, but if it’s wiring, I’ll most likely have to do that myself. The cruiser has started every time since Wednesday morning with one failure to crank on the initial turn of the key but it cranked on the second turn...so I’m thinking that the plunger either isn’t making a great connection or is so gunky that it’s failing to engage at all (when it doesn’t start).Any update on your issue? Were you able to get something figured out?
How did you access the top bolt? That was literally the only part I couldn’t get to...although the ground off of the solenoid was pretty inaccessible as well.Glad it is coming together for you. I've pulled the starter on mine before and don't recall it being to terribly hard. Been a few years though.
