need a compressor hose
Utah
rubber? i have a 25foot pvc one which would be fine as an extension, but
it's so stiff it makes it a pain to use. i was thinking about a rubber one... not one
of those little coil jobs, but like a garden hose type rubber.
something like this?
http://cgi.ebay.com/NEW-GoodYear-Br...ryZ22664QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
where do you guys buy? what do you use?
it will go outside, but probably doesn't need to be some super industrial
type thing.
That's similar to what I use. I bought mine at Home Depot and probably paid double that. If you have a Harbor Freight nearby, they usually have one stamped goodyear for under $20. As you figured out, the key is to get a rubber one, not PVC.
Rubber is good, but with mark woodwork, etc. if you are dragging it around inside the house. I agree that the PVC ones are a real PITA.
Maybe red rubber. These thiings last forever.
M
Buy some push-to-connect hose and appropriate fittings from mcmaster.com.
It is top notch stuff, does not use hose clamps, stays supple and lasts a long time. It is what I use on all my OBA installations. (Done about 5 by now)
Parker push-lok is the best you can get. It's also very pricy.
The barbed pushlok fittings are stupid simple, and make it great for quick setup. (don't use clamps on pushlok fittings, it defeats the purpose. it's hard to believe, but those barbed fittings will stay in there, the hose will burst before the barbs let loose.)
Lasts a long time. There's a reason why places like paper mills and other areas with caustic envirnoments use it.
Fred
