Need a Brake Master Upgrade
Discussion in '40- & 55-Series Tech' started by TJDIV, Mar 29, 2004.
  1. TJDIV
    TJDIV Back in The U.P.
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    I have the single line triangle based brake master on my FJ40 and need to upgrade. I do have a couple double line brake masters I got off ebay but they've got the 4 bolt square base. Can these be adapted to fit on my Cruiser, or is there an upgrade out there that I'm just not aware of? I need this fix fairly soon, I'm running Dana 44 front and a 12 bolt rear, front disc, rear drum and the single line just doesn't distribute evenly enough.
    Any help would be appreciated; and the sooner the better. You just might keep me from impaling myself into something. (I drive smart though.) ::)
    Thanks. Tom IV
  2. Landpimp
    Landpimp GOLD Star
    15,905
    Media:
    1
    1,937
    Mar 14, 2003
    Gig Harbor WA
    no 3 bolt master that I know of. I used a Wardens adapter that spaced the the booster(I added it as well) and master out and converts to a 4 bolt.............then you can use almost any master or booster, I used a 74 fj40 booster and 90 mini master
    [​IMG]
  3. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,373
    Media:
    17
    Albums:
    1
    722
    Oct 1, 2003
    MN
  4. TJDIV
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    Hey Steve, that does look like something that would be worth while. I am interested in this Wardens Adapter option though. Where do I get one?
    I already have the master cyl. so I might as well go this route.
    Thanks. Tom IV
  5. TJDIV
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    I googled it and came up with:
    wardens@d-web.com <wardens@d-web.com>
    \wardens auto repair. The adapter is $95.00 but that's not their contact info. |Any help here??? Thanks.
  6. Poser
    20,373
    Media:
    17
    Albums:
    1
    722
    Oct 1, 2003
    MN
    I exchanged emails with Danny Warden before Christmas last year when I picked up two of his billet t-case nose cones, and was told by him that he was not really interested in making any new brake adapters, or any more nose cones, since they closed up shop a year ago...
    Good luck!
    -Steve
  7. TJDIV
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    How hard do you think it would be to make something up? It can't be too incredibly difficult if I had something to go by.
    Tom IV
  8. CruisinGA
    CruisinGA
    6,168
    16
    Mar 27, 2003
    Georgia Tech
    The only reason you can't drill and mount a normal 4 stud master/booster is because the firewall rib/clutch slave is in the way. Relocate/ space so that isn't an issue and you're in buisness. I don't think you would have much of an issue.
    While your at it, try to get one of the tandem boosters that came on later 40's, I believe (or at least they seem) more powerful than the single boosters like what Pimp showed and I have.
  9. Poser
    20,373
    Media:
    17
    Albums:
    1
    722
    Oct 1, 2003
    MN
    Tom-
    You can make up whatever you want, and no, it is not really that hard to make up...if you have done engine swaps, and can not make a brake booster/adapter, you are in trouble... ;)
    Take 1/4" plate, and mirror the bolt patterns, get a piece of round stock 4" round or close to that, and you should be able to figure out the rest...
    Good luck!
    -Steve
