CenTXFJ60
Confirmed...I don't have a BVSV. Not even a place to tap one. Is thisView attachment 1471276 Another member sent me this diagram (thanks @sami ). The motor in my shop is set up just like this. I believe my issue is the coaster motor does not have the BVSV on the side of the block along with a few other things. Can someone explain the function of this? I assume it's temp related.
Most vacuum pumps have a cut off valve that maintains around 6psi of vacuum.My issue is the vacuum pump seems to be overpowering the VSV and shutting down the motor
Rosco, this is an AC motor. Interesting comment on the cut off valve. It makes sense since my motor runs for a minute or two and once the vacuum canister builds pressure the motor dies. I do have good oil pressure as well. Been running it quite a bit as I've been putting it together. Would like to see what that cut off valve looks like. Also, not sure what BVSV stands for but it's in the diagram and standard on 12HT's out of 61's.Most vacuum pumps have a cut off valve that maintains around 6psi of vacuum.
I only know of 2 vacuum diagrams for the 12HT. One for aircon equipped models and one without aircon.
Do you have a 24v or 12v engine? I think the Coasters are all 24v
What does the BVSV stand for?
Oz, I don't have an idle up on the back of my pump. I have a bosh alternator. Have a stock one on another motor and will take a look at it. The power for the vsv (in the square) is coming from the brake master line (arrow)That would be the vacuum operated idle up on the back off the pump for the air con and cold starts. It sounds like something is shutting the engine after start up that's why I was thinking oil pressure. Where are you picking up power for the VSV
Right after I did this post the VSV started working again. Very frustrating. Now that the key is working I am moving on to some other things (valve adjustment and changing crossover pipes). Then I'll rewire the VSV directly to the fuse box.Oz, this thing is driving me crazy. It literally works and then stops working. Whenever it stops, I'll try all 3 VSV's I have and none work. Then when it's working I'll switch in the other VSV's and they will work as well. I've tested each one on a 12volt battery as well. I'm at a loss with this thing. I have a brand new VSV and 2 used ones. I've plumbed it up just like the diagram above except I don't have the BVSV. Don't think that matters as long as I have a closed system. I've even tried separate wire harness clips with the different VSV's to see if I can get it to work. If I understand the concept correctly it is....12volts to the VSV while engine is running. This keeps the valve open so vacuum escapes. Once power is killed the valve closes and vacuume pulls the diaphragm and shuts off the motor. I believe this is correct and have had it working a few times and able to shut it down over and over with the key. Then I wait a bit and it does not work as I can't start the motor. Is there some electrical or mechanical pressure regulator that I'm missing????
Oz, I believe you are right. I think through these many issues while falling asleep. And bam...it hit me the other night that this wire harness had some issues on the ground block feeding the drivers side engine area. My son and I looked at it prior to installing it and figured it was not gonna be a problem. Had some burn areas and tape where some patchwork was done by a PO. In the end, I think this is my issue. Will strip down that side of the harness and redo all the grounds. Got some other things to take care of first (turbo reseal and injector service). Decided to do these to ensure no issues from sitting 30+ years. The turbo is blowing oil.Maybe you have a intermediate fault in the circuit your using time to try a different source from ignition. I have mine wired into the glow plug system so if there's a drop in oil pressure it should shut the engine off.
