- Thread starter
- #21
i'm gonna try some 4 degree shims in the front and see what happens
cruiseroutfit said:Kind've
I have never done a cut/turn so that we could put the caster back to original, seeing as original was 1-2 degrees (sometimes 1+ degree of side to side). In every case, we increase the caster to 3-6 degrees for better road handling. Toyota improved the caster on later Cruisers (FJ62's had some caster built in). So yes, the cut/turn does allow for proper u-joint angles (not just a CV joint) but it also improves the stock steering too.
bandy rooster said:i'm gonna try some 4 degree shims in the front and see what happens
Pin_Head said:Shackle?
If you have extended shackles in the front, it makes the caster more negative (bad). Save your money on the SR and just fix the caster problem. They don't have much effect one way or theother on handleing in my experience.
