NCTrey133
@Sweet_Brown_80
- Location
- United States
Update - new price $4,800
Hey ya'll, ended up switching to a driver drop axle after completely rebuilding and setting up a GM60 (I hate money).
Axle was sandblasted, primed and coated with steelit then loaded up with all the goodies
Specs: Passenger drop kingpin dana 60
5.38 gears - Yukon
Arb air locker 35 spline
Brand new seals - ECGS
1410 u joint - ECGS
Crane axle diff cover - Wide Open Design
Axle tubes all cleaned up, fresh slate
Brand new dana 60 knuckle rebuild kit - Wide Open Design
Crane axle hi steer knuckles and interlocking keyed arms - Wide Open Design
Crane axle spring eliminator kit - Wide Open Design
All new hub bearings - ECGS
New 35 spline slugs - ECGS
Chromoly 35 spline axle shafts inners and outers - Yukon
Yukon super joints - Yukon
Brand new spindles, spindle bushings and axle shaft seals/stone guard - ECGS
Brand new 3/4 ton brake kit - lugnut 4x4
Brand new wheel studs
Barnes GM dana 60 axle truss - Barnes 4wd
Gears and locker were setup by Andy Zuber. Axle is built and ready for the truss to be welded on when you set your pinion.
$4,800 OBO
5.38 gears - Yukon
1410 u joint - ECGS
$4,800 OBO
