Nav System says I'm driving in the Atlantic Ocean - how to recalibrate
Discussion in '100-Series Cruisers' started by fnpierce, Jul 17, 2017.
  1. fnpierce
    fnpierce
    113
    80
    Oct 13, 2013
    I know I've seen this before but can't find it when searching. What is the magical sequence to recalibrate the Nav System/GPS? Thanks
    2003 LC
  2. Phrog
    Phrog
    214
    20
    Oct 30, 2004
    Steamboat Springs, CO
    fnpierce likes this.
  3. Mark WV
    Mark WV
    112
    Media:
    9
    Albums:
    1
    52
    Mar 12, 2017
    Milton, WV
    Do you have the green GPS indicator showing up on the screen below the North Arrow on top left of screen? If not, then likely you do not have a GPS signal going to the GPS Unit - Possible it is a bad GPS antenna.
    You can try removing the DVD, and then reinstalling it to see if that helps - DVD is under the passenger front seat - remove the plastic cover from the rear of the seat and you can eject the DVD. Then Turn everything off and then reinsert the DVD and start up the vehicle, giving it 5 minutes to reload the system. Do this outside where it should be receiving a GPS Signal. I doubt this will solve it but who knows
    If you still don't have the Green GPS indicator on the screen then it is likely a failed antenna - see this link below for additional details
    GPS not working
  4. fnpierce
    fnpierce
    113
    80
    Oct 13, 2013
    Thanks! That's what I was looking for.
  5. HiFiGuy
    HiFiGuy
    102
    15
    Nov 6, 2006
    Fairhope, AL
    Have you considered that your GPS is fine, and you are actually driving in the Atlantic? I mean, LCs are pretty bad-ass. Just sayin'.
    Spike555 likes this.
