Fine folks, I'm replacing my furnace and wanted the wisdom of mud. First some "must haves":
1. Natural Gas Furnace
2. Horizontally Firing (orig. config.)
3. At least 80% efficient.
4. As safe and as reliable as possible.
Some "wanna haves"
1. Some additional filtration ability.
2. Humidifier ... preferaby one without the drain tube (self cycling)
3. At least two stage operation (70% to 100% duty).
4. Possibly that variable setting stage where it will fluctuate from 15% or so at minimum all the way to 100% and where the house fan will always flow air through the filtration part in number 1.
What I do not feel fully competent in is chosing stuff like:
1. Is 80% AFUE good enough or should I insist on 90%???
2. Do those additional filters work? Any particular model worth of recommendation?
3. Between two stage and the variable setting stage, which is it?
4. Is it practical to constantly run a fan for filtration purposes. In other words how much will it work to remove airborne dust and debris?
5. All the other things I'm not think about that I should think about. I'm really liking Rheem furnaces, BTW. Seems pretty solid.
Thanks. There is comfort within the wisdom at MUD!!!
Some "wanna haves"
