NaterGator
On Gilligan's Island
Eyup. This is my first time so as I pull stuff apart and start to tear into the axle I'm going to need A Few Good Mudders to give me some guidance.
A brief relevant history. About 20k miles ago I had a fairly catastrophic bearing failure on the interstate on the way to catch a flight to my brothers wedding. See here: https://forum.ih8mud.com/80-series-tech/162109-cruiser-failure;-i-had-get-towed-now-dealership.html
To start, I've just started pulling apart my DS hub. One of the nuts annoyingly ruined the threads on a stud so I'll be getting new nuts and a stud for the hub. Not a biggie, kinda to be expected I guess.
However about 15k miles ago (maybe a bit less, maybe 10k) I had my dealership check and grease my wheel bearings because I was going out of town and felt it needed a once over (the $2k repair fresh in my mind). Here's what I've found that concerns me a bit.
First off this is all DS and this is as far as I got before it started pouring rain (like one of the only times this year, of course b/c I'm working on the cruiser
). This is a bit of wear I'm seeing on the bottom of the spindle from the outer bearing I suppose:
That looks like very abnormal wear to me, especially for a "new spindle" with about 20k miles on it.
Following along here is the outer DS bearing:
Again obvious corresponding wear pattern to the spindle. Is this indicative of excessive heat (ie: from improper lubrication?)
This brings me to my final question/issue: this all looks suspiciously colored like moly grease, no? AFAIK moly grease looks greenish/grayish/bluish and regular bearing grease looks red. The M1 syn grease I have for the repack is most certainly red. Here's the overview of the spindle which otherwise seems to be in good shape other than the wear on the outer bottom surface:
So is this a matter to concern myself with? Does this warrant replacing timken wheel bearings that can't be more than 20k miles old? Or am I being a paranoid newbie and everything looks pretty good?
As soon as the rain abates I'll be tearing deeper into the knuckle and moving to the PS side. Hoping to find all is well elsewhere. So far the FAQ and FSM have made this process pleasantly predictable and easy-to-do. I just don't really know from experience what I'm looking at as this is my first-ever bearing/axle R&R on any vehicle
TIA.
-----Nate
TIA.
-----Nate
