Mystery Leak - Passenger Side Under Heater Core?
Changing my coolant.
Got the LC up on drive-up ramps.
  • Noticed what I suspect "could" be a coolant or other fluid leak on my passenger side
  • Wet greasy coating mix did not smell sweet but a little slippery
  • The blue arrow areas should be dry with road grime only
Drained almost 4 gallons of coolant/antifreeze from the engine block and radiator - so not thinking coolant.
This is supposed to be what that area looks like dry:
Right now, she doesn't have any coolant on board.
Your thoughts?
Steering rack or hoses from PS reservoir
Thanks guys - I'll check those.
@clrussell. The axle boot looks to be in good shape but which end is the seal on?
@JunkCrzr89 - the power steering reservoir hose going down and forward towards the fan assembly does have some wet grime on it.
