Just picked up a 91 HDJ81 and had a hard time locating this hose as Im about to do an overhaul on some high wear items before a trip down to Moab. Its located on the hard pipe after the upper rad hose and has an extreme bend that is a bit concerning. I could not locate the part in the parts diagram and was curious to know if anyone had a link on this part. While I'm replacing the upper and lower rad hoses, are there any other hoses I should order while im in the engine compartment that would safeguard me on a long hot desert trip? Will probably end up doing the rear heater bypass as well.
I've circled the hose in question and the area it should be located around in the parts diagram (unless I'm incorrect about the location)
