I’ve been having this coolant leak and I do not know what this piece is called where’s its coming from. Any ideas guys?
If you haven't done this already, clean up the area really well, then use the AC to see if you can trace the leak. It will save you form having to replace more than you need to. From my guess in looking at it, the leak seems to be coming from the hose and then pooling up at the hard line connection. This can give you the impression that the hardline is leaking but it is likely not. If it is just the hos/clamp - super easy fix as noted above. If it is the gaskets at the bottom, those are not hard either, but just a little more work - They don't look too bad but if you do need to change the gasket I would spray some liquid wrench or something on those nuts/bolts before trying to wrench them off.See in Orange... basically this hose and/or clamp is bad. Your best bet is to replace both to be safe. You can see the coolant drip down the hard-line. The other items in orange have gaskets which can also be easily replaced. Check with Norwalk Toyota for prices.
