Mysterious oil Container... Need Help Identifying (w/ pics!)
Connecticut
Hi.
My rig has this oil bottle (for lack of better term) mounted in the engine compartment.
Some facts:
1983 RHD from AUS
Dual fuel set up
It is definitely not stock- it is mounted in a water bottle holder from a 10 speed- to the radiator mount. There is a vacuum line that goes from it (with some kind of screw valve) to a tee off of the carb. The other 'end' of the tee goes to part of the propane system.
Is this some sort of lubricant for the propane system??
If so (or if not) what type of oil is in there??- it doesn't taste like motor oil...;)
Thanks!
Some Pics...
Tear Gas Anit Teft Device ????
Mark
I'd take a guess that it is to lube something and likely uses compressor oil like the rotary vane vacuum pumps at my work. You'll need to explore what it's hooked to unless someone else has sen this before.
...or some form of performance additive?
