My RPM is 2800 and my speedo says 65mph
USA
My RPM is 2800 and my speedo says 65mph with 31x 15 tires
I checked my speed against radar speed signs (which are placed along the road in my city)
What does your Land cruiser RPM to speedo say?
Thanks for giving me a reason to fire up the cruiser... GPS shows me 5mph faster than my speedo.
FJ62
Tires = 31x10.5
Speedo 55/GPS 60 = RPM - 2350
Speedo 60/GPS 65 = RPM - 2500
Speedo 65/GPS 70 = RPM - 2600
Speedo 75/GPS 80 = RPM - 2900
In fourth gear my speedo says 65mph and my rpm is 2800 w/31x10.5 x15 wheels
anybody have H55f trany?
curious what the numbers are with bigger tires
With 3.7's and 31's and a 5 speed you would be at about 78 mph @2700 and 65 mph at 2250.
AfricanToy: the relationship between RPM and the speedometer reading will not change with bigger tires. the speedometer measures the vehicle speed at the transfer case ouput shaft, so any changes farther downstream (ie. tire size, ring and pinion gear changes) will be invisible to the speedometer. What does change is actual speed.
Since the H55F has an 0.845 5th gear ratio, if you had an H55F in your truck and nothing else changed your tach would read (0.845*2800)=2366 RPM at 65 mph.
If you become obsessed with knowing how fast you are really going, you should look into purchasing a GPS.
FJ62
Tires = 31x10.5
It is not a linear number (5mph)
It is a percentage of your speed. 10% of 55 is 5 mph
10% of 60 is 66 mph
10% of 70 is 77 mph.
2mmb is right.
Yes, I did a search to try to find out the answer for myself...
Not to steal the thread,(as it seems the issue has been resolved),
but how do you figure out your actual mpg when using taller tires?
For example, my rig (fj60 with 31'tires) got x mpg. What calculation
do you do to compensate for the larger than stock tires when trying
to determine actual mpg?
I have the 5spd...
My truck is set up with H55f and 4.11 and 33's...and a regular ol'2f in fine running condition.
In 5th, at 2500rpm I'm doing 70
You know how many gallons of gasoline you use between fill ups--that number does not get corrected.
However, the odometer reading is not accurate because you've changed the tire size. You correct to odometer reading (measured miles) to get actual miles by multiplying the measured miles by the ratio of diameters of the tires (new tire diameter divided by old tire diameter). If the stock tire size is 28" and the new tire size is 31" and your odometer says you traveled 100 miles, then the actual number of miles traveled is: 100*(31/28)=111. This represents an 11% increase.
You can also use this factor to correct the speedometer--multiply the speedometer reading by 111% (i.e. increase the speedo reading by 11%) to get "true" speed. If your speedo say's you are going 60 mph, you are really going 66.6 mph.
If you've changed your ring and pinion gears from stock then you need to factor in that correction too...
Intresting "You can also use this factor to correct the speedometer--multiply the speedometer reading by 111% (i.e. increase the speedo reading by 11%) to get "true" speed. If your speedo say's you are going 60 mph, you are really going 66.6 mph"
I have the 31" tires and when I tested my speedo against the local radar sign it matches up? anyway I understand your theory however my speedo seems to be right...or wrong?
I am considering 33" tires 33/28 = 1.18 or 18%
therefore 65 mph = actual 76 mph
meaning 2800 rpm = 76 mph w/33" tires
My HJ60's speedo show the correct speed with 32" tires.. with 31" it shows lower than real speed. and with the original tire-size it's way off.... shows 80km/h when going 70km/h... all cars do that... to insure we don't break the speed-limit by accident...
But i'm not 100% sure the odometer is calibrated the same way... if it is, the car has actually gone 10-15% shorter than the odometer says...and in my case that's 40000km!
(on the other hand it's the number of revolutions and movements in the car and not the length of the road that matters when we talk milage)
The way I figured my odometer error due to larger tires was; Reset trip odometer, run the vehicle for 100 measured road miles ,measured from the mile markers on the road. At the end of the measured 100 miles take your trip odemeter reading. Mine was 86 miles indicated . 100 miles divided by .86 = 116.28 miles traveled per every 100 miles my odometer registers. Whenever I travel a long distance, I check for this error and and if it changes slightly due irregularities such as errors on the highway dept. placement of the mile markers, I average the divisor accordingly. Speedometer error can be figured with a stop watch and a steady foot on the gas pedal or using cruise control( no pun intended) 60 mph = 1 mile traveled in 1 minute . so if a train left chicago at 7:00am traveling at 60 mph and then a trian left new york at 9:00 Am eastern time and then.............. did we not do this in jr high math class.
I disagree, if you use larger tires you need to apply more torque to the drive train to turn the tires. so you may say that the drive train is moving slower and less revs for all of the drive train components equals less wear , but the applied torque to the drive train is greater and above the design specs that the engineers figured for the vehicle using stock sized tires. 6 of one .... 1/2 dozen of the other .... it may be a wash or it might not .......
i can top that. mine was sittin on 3k today while driving 65mph. i've always wondered if that was too high.
I think the perfect speed to RPM ratio for the land cruisers should have been 2500 rpm @70mph (top gear)
is that 70 mph on the spedo, or actual 70 mph , with you already taking into account the tire size calculations?
i run 33's on my FJ60 4 spd, and i have calculated with the GPS 16% difference.
actual speed (any conversion) 70mph @2500rpm
i think i am more in the 64-67 mph at 2500 rpms. sounds like i am going to explode with my pilot bearing whine i have.
