Hi Guys,
New to IH8MUD, Although I have been studying this forum like I have never studied anything before this last month.
So this is my Santa Cruiser and Jesse James. They both just have such big nosses.
1990, CA, FJ62 with 224K. Runs really smooth. Have not done compression yet. Starts right up and idles nicely around 650 rpm. Has a winch, roof rack, 4 inch lift, ARB compressor and allot of dents. I am going to try and remove the dents myself and repaint the spray can way.
This truck has been well taken care of most of its live although by many different shops so there are some funny aftermarket things.
The PO had it sit for a while over the winter and rats took over. Build a nest under the hood and next time they drove there was a bit of a highway bonfire. All the hoses where replaced but some of the wiring has been chewed trough and not fixed. Most of the wires that are damaged involve the air compressor.
Part of the nest was right on top of the transfer. The thing were the arrow points to, the wire is completely striped of. Do you guys know what it is and were to get it? The rest seems pretty easy to fix.
The 4x4 (4H, 4L) work fine though although the 4wd light doesn't come on.
The check engine light comes on about every min. for about a minute. and then go's away.No matter if engine is hot or cold. with no difference in performance when it comes on. Code 22 and 71. What I did so far is just cleaning the EGR temp sensor which was pretty filthy, so i'm sure the EGR and intake a pretty black and clogged. I'm thinking about a new EGR, temp sense, gasket and such and clean the intake. The other one is water temp. sensor.
The temp. gauge on dash sits between 1/4 and 1/2. So I guess mechanical sensor to really see what the temp is? I'll probably replace that sensor as well.
Again performance doesn't seem bad.
Then there is a bit of a up and down wobble at low speed in the tires. Not sure what that could be.. And around 64 mph the truck starts to vibrate quit a bit. I red stuff here about the driveline. I'll have that looked at.
The steering is quit crappy. i feel like the PO put power steering fluid in there instead of ATF. Not much power in the steering. The truck sways from left to right quite a bit. So when I steer the response feels delayed and like your in a boat more then in a truck.. Also I feel like the wheels are directing my steering wheel. Any thoughts on that?..
Working on the kick down cable now for some smoother gas pedal action and getting the PO dogs smell out of the inside.
Appart from the regular tune up stuff. plugs,dizzy, valve adjust, all fluids, Seafoam.
Any thing else for a truck with this many miles you guys would recommend doing?
Really appreciate this forum and all the time and effort everybody puts in!
Enables the Cruiser addiction.
Thanks!
Thanks!
