devo
- Thread starter
- #21
Hey @baldilocks thanks for chiming in. When I said a DCDS doesn’t work for everyone I took that from an 80 owner who after his lift couldn’t get the front vibe out even with the dc shaft. So he just lowered his rig to solve the problem. I was thinking of lowering mine back to a respectable 2.5 but it looks like in the end the DCDS will be the least expensive? I don’t use this rig like I used to and sometimes feel like I have too much lift? Because my OEM ds is balanced in the 90* out of phase thats how I am running it. I tried it in phase and of course had increased vibrations.
I’ll look at the math you brought up in your post later! In the front I have Dobinsons springs (the best) which give me a strong 3.5” lift even when loaded. I’m using @landtank 2.5 castor plates which puts my castor within spec. If I remember, my TC flange points up at about 4 degrees and the front pinion is rolled about 2.5 degrees downward. So there is quite a twist on my OEM shaft.
I was going to contact TW with my flange angles to see if a dcds will help me? Most likely LT also.
devo
devo
