Hi all. Asking for Opinions on my results as I’ve never done a leak down before. I think it’s obvious, my rings aren’t well but wondering just how bad they are. Should I be considering a re-bore for this off-road only rig. When I got the rig in 2000, I pulled the pistons out that had broken and frozen rings. I couldn’t measure the cylinders accurately but could tell they were a bit out of round with a slight ridge on the thrust side. Not financially ready for a rebuild I honed the cylinders till the ridge was gone and installed new standard size rings. New rod bearings also. I’m not using oil, smoking or fouling plugs. I just got my first leak down tester and did a compression & a leak down test. Comp test was done hot. Leak down was done warm as I discovered a leak in the tester and had to re-test after fixing it. For the leak down, each cylinder was tested @ tdc on compression. Test pressure was 100psi. The second gauge on tester reads in percent of loss.
And for hearing air in the exhaust I really couldn't tell if I was hearing air passing through valves or just hearing the hiss in the crank case. Air out of the dip stick tube was definite. TIA.
