- Thread starter
- #61
New master cylinder rear brakes with new shoes and cylinders. New tie rods and HFS steering damper are ready to go on. hopefully, it's going to drive much better.
Content may include affiliate links. Please see terms for details.
I did not I used a bleeder tank and was thinking don't need to do that.Check your grounds for the lights issue. Did you bench bleed the MC before installing it?
That may be the issue for the soft pedal.I did not I used a bleeder tank and was thinking don't need to do that.
I changed all the soft lines to steel braided as well since I knew I was going to bleed the brakes anyway. I just read that I may have to adjust the drums all the way and not back them at all and do the bleeding. I'll do that tomorrow if wife agrees to help again 😁 and see if that helps.I had an issue with my brakes last year. Same type issue, could not get the air bled out. I put new master and slave in, bench bled the master, still air. Check and rechecked and could figure out where the problem was. So i looked the soft line up and down, no leaking fluid no visible problem. I ordered new soft line. Problem solved.
